Condenser Replacement
11 replies to this topic
#1 ac427
ac427
  • 679 posts
Posted 14 September 2024 - 02:13 PM
Is it possible to replace the condenser in a 59D4 distributor without disturbing the points gap ?
Edited by ac427, 14 September 2024 - 02:14 PM.
#2 Ethel
  • 26,073 posts
Posted 14 September 2024 - 03:17 PM
Yes, but if the condenser has failed it's likely the points will need looking at.
You just unhook the wire from the end of the spring. Take care to ensure the spring goes back in the plastic  isolator so there's no short & the braided earth lead is reattached under the condenser mounting screw.
#3 ac427
ac427
  • 679 posts
Posted 14 September 2024 - 04:05 PM
Thank you Ethel. I have been reading through the Haynes manual but it wasn't clear. I couldn't be sure from looking at the distributor with rotor arm removed ether.
#4 Ethel
  • 26,073 posts
Posted 14 September 2024 - 04:58 PM
Expect there's a Youtube vid, but if you just look at some retail piccies of the points & condenser it should be pretty obvious how they go together.
From all angles
#5 Cooperman
  • 23,326 posts
Posted 14 September 2024 - 08:09 PM
With the unreliability of condensers these days I now have two mounted outside the distributor. I have them on the triangular bulkhead bracket just in front of the brake and clutch master cylinders. One is wired in and the other is available if the first one fails. It takes a minute to change the wire from one to the other.
#6 floormanager
floormanager
  • 717 posts
  • Local Club: Mini Club Sussex
Posted 14 September 2024 - 08:57 PM
Either buy them from The Distrubutor Doctor (top quality) or fit a competition condensor outside of the distributor.
#7 ac427
ac427
  • 679 posts
Posted 14 September 2024 - 11:27 PM
Thanks. I had not heard of the Distributor Doctor before.
I already have a new Mini Spares condenser, the £10 with the 3m of wire in it.
Edited by ac427, 14 September 2024 - 11:28 PM.
#8 mab01uk
mab01uk
  • 12,538 posts
Posted 15 September 2024 - 08:34 AM
I agree Distributor Doctor if you want better quality and reliability:-
https://www.distribu..._condensers.htm
Edited by mab01uk, 15 September 2024 - 08:34 AM.
#9 68+86auto
68+86auto
  • 1,011 posts
  • Local Club: Queensland Mini Car Club
Posted 16 September 2024 - 05:22 AM
The good minispares ones are actually the distributor doctor ones. The last one I got had the distributor doctor label on it.
Edited by 68+86auto, 16 September 2024 - 05:23 AM.
#10 Shooter63
Shooter63
  • 1,079 posts
Posted 16 September 2024 - 06:41 AM
The Minispares quality rotor arms are also DD, for the price difference its a no brainer.
Shooter
#11 68+86auto
68+86auto
  • 1,011 posts
Posted 16 September 2024 - 09:37 AM
I thought I'd bought some of these before but this is the only one I've noticed the label on.
Attached File  IMG_20240916_193611_(2040_x_1920_pixel).jpg   49.57K   2 downloads
#12 ac427
ac427
  • 679 posts
Posted 19 September 2024 - 07:05 PM
Ah, I didn't know DD sold the condenser already had. Nevermind, i got some much nicer distributor caps and a couple of sets of points too.
