What The Hell Is That?
Posted 20 September 2024 - 09:29 PM
Posted 20 September 2024 - 09:54 PM
Posted 20 September 2024 - 10:00 PM
Fuel injection or carb tank? On my sender it had an o-ring over the floats, I think to stop the plastic float rubbing the bottom of the tank when it's empty. I fitted a eBay sender last year and it lasted about 6 months till the floats filled with petrol and it showed empty all the time. Buy a mini spares one.
Cheers Isto. It's a carb set up. So when I fit the new one should I try fish these out? Any thoughts on how much fuel is in there, at that level?
Posted 21 September 2024 - 06:40 AM
Hi
I fitted a Minispares one, cannot remember how long ago. A few years.
Recently emptied out the tank to replace all the fuel line rubber tubing and low and behold the above mentioned O ring came floating out of the tank.
It looks as if there two in there.
Paddy
Edited by Designer, 21 September 2024 - 06:41 AM.
Posted 21 September 2024 - 07:25 AM
Hi
Paddy
Thanks Paddy. It looks like mine has had multiple new fuel sender's then, each one losing an o ring?
Posted 21 September 2024 - 11:47 AM
I just used a 20 litre can and sucked all the fuel out of mine, to be fair mine is a daily and I know once I brim the tank I can get 3 days commute before my tank is in the red. As long as the fuel level is below the sender you can change it without any problems just be mindful as you do it.Cheers Isto. It's a carb set up. So when I fit the new one should I try fish these out? Any thoughts on how much fuel is in there, at that level?Fuel injection or carb tank? On my sender it had an o-ring over the floats, I think to stop the plastic float rubbing the bottom of the tank when it's empty. I fitted a eBay sender last year and it lasted about 6 months till the floats filled with petrol and it showed empty all the time. Buy a mini spares one.
You can fish the o-rings out but I don't think they will cause any harm if you can't get them. Either way whatever you do make sure it's ideally outside when you play with fuel, safety safety safety.
Edited by lsto, 21 September 2024 - 11:51 AM.
Posted 21 September 2024 - 03:07 PM
Posted 21 September 2024 - 06:32 PM
Posted 21 September 2024 - 10:29 PM
Posted 22 September 2024 - 03:14 PM
Posted 22 September 2024 - 03:21 PM
The bend on the injection one is to avoid the fuel pump. Id buy the carb one if your unsure as it's cheaper and if you remove your old one to find it's an injection version you can just bend the new one to match the original. People have done this before without any issues.
If you bend one though doesn't that alter the length of it, and in turn alter the ratio it lifts to send the signal to the guage?
Posted 22 September 2024 - 03:24 PM
This is what I'm seeing in my tank. Bear in mind though, this isn't working either😂The bend on the injection one is to avoid the fuel pump. Id buy the carb one if your unsure as it's cheaper and if you remove your old one to find it's an injection version you can just bend the new one to match the original. People have done this before without any issues.
instasize_240922162214.jpg 47.31K
4 downloads
Posted 22 September 2024 - 07:52 PM
Posted 22 September 2024 - 08:46 PM
Posted 24 September 2024 - 07:46 PM
Before ordering one I thought I'd test the one I have. Ran the petrol down and removed it from the tank. Reconnected the wires and put it through its motions. When it reads empty on the guage, and when it's against the lower stop tab, there is still enough juice in the tank to be just below the sender aperture. When I moved it to the 'full' tab it reads 3/4 on the dial. So working but not very helpful. I put 2 very slight bends in the arm. One to allow the float to dip lower into the tank before the stop, and another to allow the arm to rotate more before it hits the full tab. When all put together the lower reading on the guage was now about 15 - 20% fuel remaining, instead of the previous empty. Nipped to the petrol shop and filled up with the missus watching the guage with the key turned. Stopped when full. Checked with cameras and it's just touching the neck. Only thing remaining now is to run it to red and hopefully not run out🥴👍
Edited by Rubbershorts, 24 September 2024 - 07:47 PM.
