Where To 'borrow' A 5/16 Nut From?
11 replies to this topic
#1 jiminwatford
jiminwatford
  • 314 posts
Posted 24 September 2024 - 09:57 AM
I'm just replacing the head gasket and one of the nuts has got stuck on one of the rocker studs. I ordered a new stud and asked if they would include a new nut but no luck
To get the engine back together where could i borrow a nut from on the car until i can get to my spare engines in a few weeks time?
I imagine these nuts are common throughout a Mini but i can't think off hand where to 'pinch' one from
#2 stuart bowes
stuart bowes
  • 2,530 posts
Posted 24 September 2024 - 10:09 AM
this might not be the right one but when you look at minispares to buy a nut, it lists out where they are on the car:
http://www.minispare...ck to catalogue
for example, see right side
#3 jiminwatford
jiminwatford
  • 314 posts
Posted 24 September 2024 - 10:19 AM
That's pretty great
It gives me a clue where to look for one
#4 68+86auto
68+86auto
  • 1,344 posts
  • Local Club: Queensland Mini Car Club
Posted 24 September 2024 - 10:59 AM
What do you mean by stuck on one of the studs? can't you remove the nut?
#5 Ethel
  • 26,580 posts
Posted 24 September 2024 - 11:37 AM
Rear heater bracket? - nope 1/4UNF
Was trying to think of a nut 'n bolt combo you could swap for metric, front subframe mountings?
#6 nicklouse
  • 18,998 posts
Posted 24 September 2024 - 12:49 PM
Can’t think of anywhere that uses that nut. Other than the brake/clutch pivot shaft. Normally a nylock.
#7 Ethel
  • 26,580 posts
Posted 24 September 2024 - 01:31 PM
How about the battery strap? That's one you could manage without at a push, that's also easy to get at. As long as you don't leave the strap swinging to short the battery posts, a cable tie could sort that.
#8 Designer
Designer
  • 733 posts
  • Local Club: LSMOC
Posted 24 September 2024 - 02:00 PM
Hi
If you have got a new stud can you not put the old one in a vice heat the stuck on nut and hopefully remove it that way.
Paddy
#9 DeadSquare
DeadSquare
  • 3,375 posts
Posted 24 September 2024 - 02:43 PM
My coil is held on by a couple of 5/16" nuts and bolts.  One would probably be enough for 'just running round town' .
#10 jiminwatford
jiminwatford
  • 314 posts
Posted 24 September 2024 - 02:48 PM
I don't know how it happened but the nut is threaded on the stud and the more I try and remove it the more stuck it gets. So far as the nut has come off I can see the threads below it are buggered
I had to go out so called in at a Land Rover specialist and got a nut from them
So hopefully get the Mini back together later on
#11 DeadSquare
DeadSquare
  • 3,375 posts
Posted 24 September 2024 - 02:53 PM
With a big 3/8th" head stud through the rocker pedestal, is it vital for the locating stud to also be bolting it down ?
Most of the locating stud's job, is to keep the rocker gear attached to the head when the head is removed.
#12 GraemeC
GraemeC
  • 7,467 posts
Posted 25 September 2024 - 08:17 PM
I can think of a few places that has that nut, but not sure if I'd pinch from any of them!
Master clyinders
Engine mounts to subframe
Gear selector to tunnel (on rod change)
Exhaust mounts
Engine steady (bulkhead end)
Steering column bracket
Thermostat
Alternator mounts
