Bad Ignition Switch?
8 replies to this topic
#1 MattMINIMayfair
MattMINIMayfair
  • 32 posts
Posted 26 September 2024 - 12:36 PM
Hello all,
I am wondering whether I need a new ignition switch.
When I got my Mini the keys were lodged in the barrel. When I managed to get them out they were slightly corroded.
The car has never started with the keys in the ignition. I have replaced the wiring loom and the relays and the car is earthed. It won't start using the key.
When I turn the key it sometimes doesn't turn and when it does the barrel makes a loud clicking sound. It is the barrel making this sound. Do I need a new barrel?
Thanks,
- Matthew
#2 Ethel
  • 26,027 posts
Posted 26 September 2024 - 01:20 PM
I don't know anything about the MPI immobiliser, but if I heard a clicking sound, I'd be looking at the relays and/or starter solenoid - that's assuming the battery has enough oomph in it to crank the engine.
#3 MattMINIMayfair
MattMINIMayfair
  • 32 posts
Posted 26 September 2024 - 02:30 PM
Hi Ethel,
My Mini isn’t an MPI, it’s an 1989 Mayfair and I have already replaced the starter relay and the solenoid and starter are okay. The battery is brand new.
The noise is definitely coming from the barrel, I am wondering if I need a new barrel.
Thanks,
- Matthew
#4 84 City E
84 City E
  • 54 posts
Posted 26 September 2024 - 02:55 PM
Hi Ethel,
Thanks,
- Matthew
Is it like a metallic click/thunk kind of noise, is it possibly the steering lock disengaging when you turn the key, if you grip the steering wheel and jiggle it slightly left/right does the noise get quieter?
#5 MattMINIMayfair
MattMINIMayfair
  • 32 posts
Posted 26 September 2024 - 04:25 PM
Thank you for the suggestion 84 City E, it could be the steering lock actually. Should have thought of that. I’ll test it tomorrow because I don’t have access to the car currently.
I’ll be back tomorrow with an update.
Thanks,
Matthew
#6 MattMINIMayfair
MattMINIMayfair
  • 32 posts
Posted 26 September 2024 - 04:28 PM
Hi Ethel,
Thanks,
- Matthew
 It does sound like a metallic clunk sound.
#7 MattMINIMayfair
MattMINIMayfair
  • 32 posts
Posted 04 October 2024 - 01:34 PM
Hello everyone.
All sorted now the engine turns over with the key.
Thank you for all the suggestions,
- Matthew
#8 stuart bowes
stuart bowes
  • 2,208 posts
Posted 04 October 2024 - 02:12 PM
glad it got sorted, what was the issue in the end? and how you solved it, it might help others in the future
#9 mini-mad-mark
mini-mad-mark
  • 859 posts
  • Local Club: northants wot no brakes
Posted 05 October 2024 - 09:01 PM
Hi Ethel,
Thanks,
- Matthew
FYI - the reason Ethel assumed MPI was because you posted in the injection minis section (for future reference)
