Gearbox Rebuild... Diff Bush Clearances?
Posted 08 October 2024 - 07:16 PM
Posted 08 October 2024 - 10:19 PM
The plastiguages (squash strips) won't work.
You ideally need to measure them with a bore micrometer or guage. Even the cheaper option of telescopic bore guages can be used if you know what you're doing and have the patience and knack. Although they only measure 2 points so don't measure ovalality.
Ideally they should have 0.001" clearance.
https://www.theminif...ial-side-cover/
Posted 09 October 2024 - 05:30 AM
Shooter
Posted 09 October 2024 - 05:46 AM
While not the most ideal, you can check the clearances with a feeler gauge.
Posted 09 October 2024 - 09:21 AM
Posted 10 October 2024 - 11:27 AM
Something to watch out for if you are replacing the inner pot joints, is to see if your new ones actually fit in the side plates, there has been a batch of joints which are oversize, this causes a world of pain if you aren't aware.
Shooter
got some of these from minisport a few years ago but been ok since
Posted 10 October 2024 - 11:30 AM
Posted 10 October 2024 - 11:34 AM
seems to be like this for quite sometime and issues from lots of other suppliers so not a jab at minisport as have had many good parts over the years and will go to them now.
Posted 10 October 2024 - 12:40 PM
