Ecu Reading O2 Voltage Incorrectly
Best Answer Nietro , 22 October 2024 - 11:13 AM
Hi All,
just an update for those that had a read and are interested. Mini is fixed, ended up removing the small capacitor to measure its value better, lacked the courage to change it so soldered it back onto the board. Poked aroung the pins of the Lambda Sensor Interface Amplifier and it looked like pin number 12 was moving so dabbed the pin with the soldering iron and made sure it didn't move when I gave it another poke.  Put the ECU back in the car and it all works.  Lambda voltage swinging nicely between 100mV ish and 870 mV ish and now going into closed loop and idling and revving well.  Little dance of joy completed in workshop and now I'm going to have a well earned beer.
cheers
Dean
Go to the full post
6 replies to this topic
#1 Nietro
Nietro
    Just On Tickover
  • 9 posts
Posted 20 October 2024 - 01:18 PM
Hi All,
I have a 1999 JDM 40th SPI Mini that is giving me some grief with more and more frequent bad running, lack of power and backfiring.  I have connected my laptop with Web MemsFCR and after ECU resetting, fault clearing and clearing the adaptable values I set up idle steps and the lost motion gap and restarted the vehicle from what I believe to be a fresh start.  All the sensors appeared to work correctly and while the car ran better it still had the lack of power and occasional backfiring. I did notice that the O2 sensor readings always seemed to read low.  I found that the green signal wire and 12v heater wire had partially rubbed thru where they are routed behind the fuel trap bracket at the rear of the injection system. This was repaired and unfortunately the symptoms didn't appear to change.  Measuring the output of the O2 sensor at the input pins of the ECU (pins 159-7 and 159-18) I get what looks to be the correct voltages going into the ECU but it still reads low on Web MemsFCR by about 350-400mv consistently.
I've ended up inside the ECU thinking there may be a dry joint on the plug or something. I found the LM9044V IC in the ECU that is the Lambda Sensor Interface Amplifier, and the voltage at the IC input pins reads the lower voltage that Web MemsFCR indicates and not the higher values that are on the ECU input pins.  After some mucking around applying heat and cold to various components I found that if I played around with a small capacitor that is across the IC input pins the ECU reads the correct voltages for a short period indicating that the capacitor is a bit suspect.  Unfortunately I cant see a value on it as it to small, would any of you gurus happen to of heard of this problem before and know the value of the capacitor by any chance.  My gut and reading of the data sheet for the LM9044V IC makes me think a 0.01uF should work but it would be good to confirm.
Apologies for the long winded explanation.  Any help would be greatly appreciated.  I would send it to the gurus but as I'm in Australia it becomes a bit of a nightmare with international postage and such.
Dean
#2 Nietro
Nietro
    Just On Tickover
  • 9 posts
Posted 22 October 2024 - 11:13 AM   Best Answer
Hi All,
cheers
Dean
#3 viz139
viz139
  • 694 posts
  • Local Club: Irish Mini Owners Club
Posted 23 October 2024 - 08:07 AM
Great investigation and result. If you have any photos of the relevant solder joints it could help others going down the same path.
#4 Nietro
Nietro
    Just On Tickover
  • 9 posts
Posted 23 October 2024 - 12:05 PM
Hi Viz139, unfortunately I didn't as I was so focussed on what I was doing, but in saying that I need to reopen the ECU and coat the new solder with somethung to help protect it.  When I do that  I will take some photos and edit them up with some information and post them to this thread.
#5 Nietro
Nietro
    Just On Tickover
  • 9 posts
Posted 23 October 2024 - 02:33 PM
Hi again I have hopefully managed to attach a few photos and a couple of PDFs to briefly describe what I figured out about my ECU to aid with the fix.  Hopefully it makes sense and some one else may find it usefull in the future.
#6 genpop
genpop
  • 531 posts
Posted 23 October 2024 - 04:28 PM
Great work,thank you! :thumbsup: :thumbsup: :thumbsup: :genius:
#7 viz139
viz139
  • 694 posts
Posted 25 October 2024 - 10:11 PM
Excellent
