Horn Recco
4 replies to this topic
#1 GermanMoreno
GermanMoreno
  • 208 posts
  • Local Club: Mainly Minis Montreal
Posted 22 October 2024 - 05:20 PM
Hello! I need to upgrade my friendly "meeeep". What horn would be a good pick? looking for a more low tone more modern sound.
and should I install a relay? 91 cooper
  Thanks! :)
#2 mini-mad-mark
mini-mad-mark
  • 883 posts
  • Local Club: northants wot no brakes
Posted 28 October 2024 - 12:48 AM
A relay will help to ensure you get full voltage to whichever horn you choose
Sorry I can't/won't recommend a specific horn; there are loads of electric horns online given good reviews but I generally use the cheapest (Ebay!) air horns on my minis as they are pretty loud and as mentioned don't hurt your wallet too much and they are a bit different sound from the norm of current cars - There should be room under the bonnet on a 91 cooper (carb, no injection gear, ECU etc?)
Bit off track but when I started messing around with minis there was no Ebay/internet - the cheapest way to a better horn was to fit something from a better(?) car from the scrapyard; usually twin (tone) horns from something like a Rover P5/P6 or similar, Jag, big Ford, big Vauxhall, even a higher model Austin/Morris /BL car often had twin tone horns
Unfortunately scrapyard salvaging is less common these days as you aren't generally allowed to go in and poke around and decide what might work on your mini (think I might start a thread on the subject of parts from other cars fitted to minis)
In Canada I guess you have US model cars in the scrapyards so hopefully you will find something cheap/loud (apologies for the UK car references that may not be comprehensible to non-UK folks)
#3 Mini ManannĂ¡n
Mini ManannĂ¡n
  • 2,860 posts
  • Local Club: man Estate
Posted 28 October 2024 - 07:44 AM
I do like my 'meep meep' but like a klaxon too :-) https://www.amazon.c...n,aps,66&sr=8-1
#4 unburntfuelinthemorning
  • 1,991 posts
Posted 27 January 2025 - 01:22 PM
Don't know if you're still looking for a horn but I installed these twin horns.  It gives a decent more modern sound and are quite loud without sounding like air horns.
#5 stuart bowes
stuart bowes
  • 2,264 posts
Posted 27 January 2025 - 02:51 PM
I put a pair of Hella Supertones on the volvo, they give a very loud 'get out of the way' when required
