I sent the below to Minisport but never got a reply. Are you clever lot able to answer my naive questions please...
I recently purchased a 1992 Mini 998cc and understood previous owner had fitted one of your stage 1 tuning kits. However there wasn't any documentation supplied with the car, so a couple of questions please...
The alloy inlet manifold is I understand water heated. I always thought the general idea was to have the intake air as cold as possible for maximum performance, so am I correct in thinking the heating is for initial startup in cold weather and thus needs to be shut off from the hot water once warm?
The previous owner didn't connect up the heated inlet manifold and I can't see instructions for how to do this on your website collateral. Can you provide me with the instructions how to implement this on the Mini please.
There is an exposed air filter as part of the kit and as the Mini engine isn't a crossflow design it will be subject to hot air rising from the exhaust manifold. Won't that decrease performance?
I don't suppose the stock Mini air filter would fit with the improved manifolds, and it wasn't supplied with the car I bought. But would an enclosed air filter taking air from the front of the car perform better and is such an item available please?
