Piston Soak
5 replies to this topic
#1 croc7
croc7
  • 810 posts
Posted 04 November 2024 - 04:32 AM
Has anyone tried and had success using Berryman's B-12 piston soak procedure to free stuck piston rings?
#2 Steam
Steam
  • 764 posts
  • Local Club: Victorian Mini Club
Posted 04 November 2024 - 07:27 AM
From experience, the best option is generic rust busting penetrating fluid (Inox, crc, wd40 etc) and time.
#3 nicklouse
  • 18,598 posts
Posted 04 November 2024 - 08:13 AM
And what might that be?
#4 Cooperman
  • 23,289 posts
Posted 04 November 2024 - 12:18 PM
Berryman's B12 cleans piston rings
#5 Spider
  • 14,885 posts
Posted 04 November 2024 - 05:36 PM
It depends on what they are stuck from.
If it's combustion by-products, I'd say there well could be other issues there. In this case, neat petrol or diesel fuel would also work.
If it's from a poor quality oil that burnt or gummed, then a change of oil to a quality brand of oil intended for diesel engines will do the trick there, but I wouldn't leave it in too long about 200 - 500 miles. These have more and better detergents than that used in petrol engines, but if it's an engine that has flat tappets, it will can result in a high rate of wear in the valve train if left in too long. Just check the colour of the oil often, once it's gone really dark and stinks, change it.
#6 croc7
croc7
  • 810 posts
Posted 07 November 2024 - 02:15 AM
Basically its pouring 1-2 ounces of a solvent (B-12) into the combustion chamber and letting it seep down the cylinder walls to the rings. Rotate the engine by hand 3-4 times, then loosely re-install the plugs to prevent evaporation.  Wait 4 hours.  Repeat 2-3 times.  To lubricate the cylinder walls, pour 2 ounces of motor oil into each cylinder and manually rotate the engine through 4 cycles.  Vacuum out the excess oil and start engine, run at idle for 5 minutes.  Change oil and filter to remove any contaminants that may have dripped into the gearbox.  Drive about 100 miles, repeat oil/filter change. I've not done this procedure and am a little concerned about bearings in the gearbox-how would they be affected by any nastiness.  But a good flush with clean oil would probably clean anything out.
