Spi Fuel Pump And Injector Not Working,
4 replies to this topic
#1 carter27
carter27
    Just On Tickover
  • 5 posts
Posted 10 November 2024 - 02:13 PM
 hi i have a 1994 mini cooper spi,
when i turn the ignition on the fuel pump does not run,
i disconnected the ecu plug and applied a negative ground to the negative cable that supplies the fuel pump relay and the relay energies then the fuel pump operates so i know that the cable  is good ,relay and pump are working.
 i applied  power to the pump and cranked the engine will not start
if i pour a little fuel in inlet the car fires up and runs on fuel till it runs out.
is there anything that can be stopping the fuel pump and injector from running .
the immobiliser  seems to be working  when button pressed flashing light goes out
has anyone any idea's?
#2 carter27
carter27
    Just On Tickover
  • 5 posts
Posted 10 November 2024 - 05:13 PM
update some readings from sykes-pickavant code reader
one error code fuel pump
map sensor 101 kpa
ambient temp 200 deg c
inlet air temp 15 deg c
coolant 12 deg c
#3 carter27
carter27
    Just On Tickover
  • 5 posts
Posted 10 November 2024 - 05:20 PM
#4 RealSlow
RealSlow
  • 24 posts
Posted 11 November 2024 - 12:45 AM
Have you checked the inertia switch? Big round button under the hood, near the firewall.
#5 carter27
carter27
    Just On Tickover
  • 5 posts
Posted 11 November 2024 - 01:54 PM
hi yes i have checked the inertia switch that is working
