Fitting 165/60 R12 tyres to 4.5" wheels
6 replies to this topic
#1 Jimmyarm
Jimmyarm
    Entrepreneur of Adult Material
  • 2,239 posts
  • Local Club: TMf
Posted 21 November 2006 - 05:00 PM
Hi All,
Though I would point this out in case anyone wondered what the strange noise coming from the back of their car is !
If you fit these size tyres onto the standard rover minilite type wheels, it is likely that you will get sufficient tyre flex under 'reasonably' (ok it was quite hard!) fast/sharp cornering you will get sufficient side wall flex for the back tyres to rub against the dampers. It makes a very disconcerting (pant browning) noise that sounds like the back of the car is going to fall off !
I have Falkens on so cant comment on Yokos or other brands.
As far as I know there are standard (unspacered) drums on the back.
Fitting spacers/spacered drums should solve this but I havent got around to that yet, just have to go a bit slower until I do !
Jimmy
#2 Jordie
Jordie
  • 13,567 posts
  • Name: Jordan
Posted 21 November 2006 - 05:22 PM
are you running drums or discs?
if you have discs up front, you probally have spacered rear drums as standard.
#3 Jimmyarm
Jimmyarm
  • 2,239 posts
  • Local Club: TMf
Posted 21 November 2006 - 05:37 PM
Discs :errr:
If they are spacered, then it isnt enough ! The wheels seem to sit quite far in at the back though so maybe someone has replaced them with none spacered drums at some point.
#4 Bungle
Bungle
    Original Spamster
  • 28,971 posts
Posted 21 November 2006 - 07:09 PM
yep most places recomand you fit a small spacer on the back
this is what i did with mine when i fitted 165 tyres on my 4.5 rims
the tyres, spacers and longer studs used to come in a kit :errr:
#5 Stoo
Stoo
  • 251 posts
Posted 22 November 2006 - 12:23 AM
I do 165 on 4.5 wheels. (Don't recommend it for handling tho'). You need 5mm spacers and you still may get slight rubbing when you corner hard enough to lose oil pressure. Don't worry tho, it will cause far less harm to your tyres than the oil pressure loss will on your engine ;?)
#6 fikus01
fikus01
  • 1,910 posts
  • Local Club: SMAG - Southend Mini Action Group
Posted 22 November 2006 - 02:20 AM
there shud be an offer on mws website - "FREE CENTRE OIL PICKUP PIPE WITH EVERY SET OF YOKOHAMA TYRES"
#7 TimS
TimS
    Mini Doctor
  • 2,712 posts
Posted 22 November 2006 - 09:13 AM
I had 165/60/12 on the cooper wheels for 3 years and never had any problems but I do have a 1/2 spacer on non spacered drums.
