It's been modded to have an additional oil filter but looking at the picture I can't see how the oil is pumped through it, any ideas?
The pipes appear, from the picture, to leave the sump front, through the filter and back to the sump front.
Posted 19 November 2024 - 03:23 PM
Posted 19 November 2024 - 04:09 PM
The middle pipe is a central oil pick-up and the return goes back in and connects to a modification of the Mini's gauze pick-up.
Posted 19 November 2024 - 04:18 PM
Interesting, does that set up enable you to ''delete'' the original oil filter then, or is it designed to work alongside the original?
Posted 19 November 2024 - 04:38 PM
There doesn't appear to be a pump in that additional filter's circuit, how does the oil go through it or is there an electric pump out of view ?
In the 80's I needed space in the front of the engine for a winch. The Oil Filter was in the way, so I made a remote fitting Oil Filter set up in that.
Posted 19 November 2024 - 04:45 PM
as DS suggests above; a 'suck-through' filter plumbed into the oil-pickup side of the pump
edit : must be a bugger to prime that circuit...
Edited by KTS, 19 November 2024 - 04:48 PM.
Posted 19 November 2024 - 04:51 PM
Edited by Gaz66, 19 November 2024 - 04:53 PM.
Posted 19 November 2024 - 04:58 PM
From ebay listing in post below:-
"Remove pre-pump filter adapters machined and fitted to the front of the gearbox casing and modified oil pickup."
Edited by mab01uk, 19 November 2024 - 05:13 PM.
Posted 19 November 2024 - 05:08 PM
Posted 19 November 2024 - 05:13 PM
If I had gone to all that effort, I would have made it part of a dry-sump system.
Edited by DeadSquare, 19 November 2024 - 05:18 PM.
Posted 19 November 2024 - 05:15 PM
OK Cheers for that.
Off hand I can't recall the reasons but these filters are not designed for suck through applications, but only for pressurized applications.
I'm very much all for thinking outside the box, trying new ideas, innovation etc but this is just not necessary and having a much long suction pipe isn't a wise idea.
Posted 19 November 2024 - 05:18 PM
Posted 19 November 2024 - 05:21 PM
That makes more sense.
I would have thought any filtering before the pump would be a good idea.
With the right type of filter, maybe.
Posted 19 November 2024 - 05:32 PM
I once thought that I'd be clever and replace the factory gauze filter with "petrol gauze".
It dropped the oil pressure from 80 PSI to about 25 PSI.
Posted 19 November 2024 - 05:41 PM
It is nothing new. I did it back in the mid 90s and other did it before me and many still do.
