Mini Cooper 1275 Spi High Emissions
7 replies to this topic
#1 Neily.M
Neily.M
    Just On Tickover
  • 6 posts
Posted 22 November 2024 - 06:55 PM
Hello,
I'm having a high emissions problem with my 92 SPI.
I replaced the air intake temperature sensor & cleared the fault but it came back but I can't believe that would cause the emissions to be around 10%.
I have checked the vac lines & the fuel trap & they're fine.
The car starts every time & idles well but it's quite smokey at times. The car also drives well & doesn't hesitate.
I have attached some data from my Rovermems reader & was hoping to get some advice if possible please?
Could the ECU be faulty?
Thanks 😊
#2 68+86auto
68+86auto
  • 976 posts
  • Local Club: Queensland Mini Car Club
Posted 24 November 2024 - 02:24 AM
What are the emissions readings?
#3 Neily.M
Neily.M
    Just On Tickover
  • 6 posts
Posted 24 November 2024 - 11:38 AM
CO is around 10%
#4 sonscar
sonscar
  • 3,031 posts
Posted 24 November 2024 - 01:52 PM
If it is smokey as you say then you should fix this first.EFI engines also suffer from all the other maladies as carb engines.Steve..
#5 Cooperman
  • 23,315 posts
Posted 24 November 2024 - 02:15 PM
How many miles has it done. You may simply have an engine with a lot of bore/ piston wear.
I had to rebuild an MPI engine which had done 92,000 miles and would not pass the MoT due to emissions. A re-bore with new pistons cured the problem completely.
#6 Neily.M
Neily.M
    Just On Tickover
  • 6 posts
Posted 24 November 2024 - 03:08 PM
The engine was rebuilt in 2020 & has only done around 3,000 miles since then.
Can you see anything in the Mems data that may point to the cause?
#7 sonscar
sonscar
  • 3,031 posts
Posted 24 November 2024 - 05:29 PM
When it was rebuilt and how many miles it has is not a good indicator of its condition sadly.Steve..
#8 Neily.M
Neily.M
    Just On Tickover
  • 6 posts
Posted 24 November 2024 - 06:35 PM
Ok, thanks, does anyone know of a reputable Mini specialist in Hampshire?
