Acceleration
6 replies to this topic
#1 propjock
propjock
  • 49 posts
Posted 28 November 2024 - 04:01 AM
Have noticed lately that every time I try and accelerate in first gear the car feels like
It’s going to stall. When I push the gas the car starts to stutter and almost stall. I recently adjusted the carb so I’m thinking it might be to lean but looking for other ideas.
#2 timmy850
timmy850
  • 3,424 posts
  • Local Club: MITG
Posted 28 November 2024 - 05:18 AM
When you say you “adjusted it” - what did you do and why?
Theres lots of things to check if you don’t know what’s wrong:
Dashpot oil
Idle mixture
Timing
Vacuum leaks
Spark plugs
Spark plug leads
Cap and rotor condition
Battery voltage while running
#3 Steam
Steam
  • 861 posts
  • Local Club: Victorian Mini Club
Posted 28 November 2024 - 08:35 AM
If it is accompanied by black smoke from the exhaust then a clogged air filter may also be to blame.
#4 gazza82
gazza82
  • 3,033 posts
  • Local Club: TMF+
Posted 28 November 2024 - 10:06 AM
I recently adjusted the carb ...
Start there!
If you add a bit of choke dows it improve? If yes, too lean. If no, poss too rich.
#5 nicklouse
  • 18,769 posts
Posted 28 November 2024 - 12:28 PM
There is nothing to adjust on an SU other than the base tickover.  Everything else needs tings changing/replacing.
#6 propjock
propjock
  • 49 posts
Posted 30 November 2024 - 02:44 PM
Start there!
It does improve!
That’s what I will check
THX
#7 Cooperman
  • 23,369 posts
Posted 30 November 2024 - 05:07 PM
Well there is also the mixture, which sounds like it's a bit out on this car.
