Coil/distributor Wiring
Posted 07 December 2024 - 05:54 PM
Could anybody post a picture of wires that show the piggyback starter solenoid, coil and distributor??
There is several white and white/black tracer wires and no idea where they go
Thanks Ian
Posted 08 December 2024 - 10:18 AM
Posted 08 December 2024 - 10:32 AM
White goes to coil positive and white black to coil negative
If it's negative earth.
Posted 08 December 2024 - 01:31 PM
By piggyback solenoid do you mean it's a pre-engaged starter where the solenoid is a smaller cylinder alongside the motor?
You only need a connection (yellow/white) to the ignition if it's a ballasted system. The solenoid feeds 12v to the extra spade terminal internally when the motor is engaged, so you need a normal, unballasted, feed from it to the coil's +ve terminal. The ballasted supply (pink/white) can either be on the same solenoid terminal as that wire or the +ve at the coil.
...It's the one marked "Yellow", Red/Brown is what makes it crank (starter relay output)
Posted 08 December 2024 - 04:34 PM
Thanks very much that helps with some wires. Hopefully have a look tomorrow and get a picture
Posted 08 December 2024 - 04:36 PM
Yes that's the one. Hopefully get a picture in next day or 2 thanks for replying
Posted 08 December 2024 - 06:00 PM
If it's negative earth.White goes to coil positive and white black to coil negative
White black trace being an earth
Posted 13 December 2024 - 09:30 PM
Posted 14 December 2024 - 10:38 AM
Find a wiring diagram,there are plenty on here,and you can work out any wiring issues,Steve
Posted 14 December 2024 - 11:02 AM
2 wires on from distributor, white and white black. Where abouts do these go? Same as before white positive and white black negative 9n coil. thanks in advance
Yes that's correct
Posted 14 December 2024 - 06:49 PM
Yes that's correct
Excellent much appreciated. Hopefully we will find out if it runs!!
