Morning all!
Got a nice little 1962 car badged as a cooper S with a few issues..
Bit of an odd one here (probably commomplace to you all) Clutch is stuck in the disengaged position. Engine off & in gear, car can be pushed easily & the engine doesnt turn. Start up & gears can be engaged without touching the clutch pedal. Clutch pedal is at the top of its travel & the Clutch Slave is fully extended.
Looking like something has gone astray with the clutch release mechanism. Anyone come across this befpore? New one on me! Going to release the bleed screw & see if that has any effect (hose collapsed?). Will let you know how i get on & would appreciate any thoughts on this.
Will put on a couiple of pics once i figure out how to..
Many thanks all!
