Coolant Type
18 replies to this topic
#1 Miv
Miv
  • 13 posts
Posted 14 December 2024 - 01:25 PM
I am thinking of changing my radiator in the spring to an aluminium one with a drain tap, does anybody know what coolant I should change to that would suit an aluminium rad and a standard cast engine ? thanks guys
Edited by Miv, 14 December 2024 - 01:28 PM.
#2 Penfold13
Penfold13
    Just On Tickover
  • 8 posts
Posted 14 December 2024 - 03:28 PM
I’ve used Prestones coolant in a few cars, claims to be compatible with everything, even other coolants, and I’ve had no issues to date. Reasonably priced and sometimes on sale in Tescos too!
#3 nicklouse
  • 18,697 posts
Posted 14 December 2024 - 06:13 PM
May I ask why? Aluminium does not transfer heat as well as copper.
oh Pink.
#4 Blumeanie
Blumeanie
  • 175 posts
Posted 14 December 2024 - 06:19 PM
I believe pink is what you need. BUT go online and read a few labels - The typically spell out metal compatibilities. You'll surely find one that suits you.
I cannot recommend a brand as we surely do not have the same ones available locally! But as Penfolds mentions above there are a few that claim close to a universal use...
#5 Miv
Miv
  • 13 posts
Posted 14 December 2024 - 08:35 PM
oh Pink.
#6 Miv
Miv
  • 13 posts
Posted 14 December 2024 - 08:37 PM
Hi nicklouse
The only reason is that I cant find an original design that has a drain fitted, but all the aluminium ones do seem to have one ?
#7 Miv
Miv
  • 13 posts
Posted 14 December 2024 - 08:39 PM
Thanks for the feedback guys will have a read up on the penfolds product.
#8 Penfold13
Penfold13
    Just On Tickover
  • 8 posts
Posted 15 December 2024 - 12:11 AM
Prestones’ product, I’m just a happy user with no links! I have Reliants too (4 wheelers…) and other owners for them recommended it and never caused me an issue to date.
#9 croc7
croc7
  • 817 posts
Posted 15 December 2024 - 01:03 AM
Hi nicklouse
Any radiator shop should be able to install a drain pitcock for you.
#10 Spider
  • 15,144 posts
Posted 15 December 2024 - 02:50 AM
Hi nicklouse
As Nick has mentioned, Copper is better for heat transfer than aluminum. You can also end up in a world of trouble through electrolysis or electroplating running an aluminum radiator.
If you'd like a drain plug, they are dead easy to add in.
First, clean the spot you'd like to add in the Drain, then tin the area, and cut the hole (I use a small fine tooth hole saw for this);-
Then drop the body of the drain on to that, a little flux, a little heat, some solder;-
Allow to cool, clean, paint, screw in the plug and your done :D
#11 Miv
Miv
  • 13 posts
Posted 15 December 2024 - 07:41 AM
Thanks very much Spider, will go with that option I think, and stick with the new but original rad.
Thanks again.
#12 Miv
Miv
  • 13 posts
Posted 15 December 2024 - 07:44 AM
#13 Miv
Miv
  • 13 posts
Posted 15 December 2024 - 07:45 AM
Sorry, I meant Prestones, silly me
#14 Spider
  • 15,144 posts
Posted 15 December 2024 - 08:12 AM
Thanks again.
I make my own brass fitting to solder in, I thread them 1/8" NPT to take a standard radiator drain plug (yes, there were originally fitted).
I don't know if you're in a position to make your own boss ? If not, you could fit something like this;-
https://www.carbuild...exphvTuJt7UgVM5
and fit an M14 plug to it.
#15 Miv
Miv
  • 13 posts
Posted 15 December 2024 - 09:05 PM
Looks just the job, thanks again spider
