Timing Chain Covers
Posted 24 December 2024 - 06:25 PM
Posted 24 December 2024 - 06:29 PM
Posted 24 December 2024 - 07:12 PM
Well you could hazard a guess depending on the timing cover type and the engine size.
but they should have had the chains changed by now and you have no idea what was used it will still be guess work.
all the A plus covers with tensioners were simplex as original IIRC.
Posted 25 December 2024 - 07:27 AM
Posted 25 December 2024 - 08:33 AM
Will an A+ cover (mpi era) fit over a duplex setup
With internal modification. Not always externally visible.
Posted 25 December 2024 - 08:44 AM
There is one small dimple in the cover that needs knocking out, but otherwise, yes.
Posted 25 December 2024 - 03:10 PM
Posted 26 December 2024 - 10:18 AM
Gentle taps are the way forward as you don't want to distort the gasket face of the cover or it will leak.
Posted 27 December 2024 - 01:04 PM
An alternative worth considering https://www.minispar...special-quality
A duplex has 50% more link, so simplex links only need to be 25% thicker, or stronger, to be as unstretchy.
There's also an IWIS chain available from KAD, Somerford....
