Have a 2000 MPI with a coolant loss. Have replaced radiator, expansion bottle. expansion cap, heater matrix and water pump. Done a pressure test which held pressure. Loosing coolant but cannot see any external signs. All help and pointers appreciated. Thank you
Coolant Loss
Posted 27 December 2024 - 06:51 PM
Posted 27 December 2024 - 06:58 PM
Posted 27 December 2024 - 07:07 PM
Posted 27 December 2024 - 07:53 PM
How full do you top the header tank to?
If you fill it to the 'Max' mark, it will vent fluid until it reaches its natural level.
Mine settles about 3/8 of an inch below the back seam of the header tank.
Try leaving it, without topping it off. Monitor the level and see if it remains stable.
Posted 27 December 2024 - 08:13 PM
Posted 27 December 2024 - 11:57 PM
Posted 28 December 2024 - 09:20 AM
Posted 28 December 2024 - 10:54 AM
This then would point to head gasket issues perhaps.
Posted 28 December 2024 - 04:45 PM
Have a 2000 MPI ...
Pictures please! (I also have a 2000).
Best of luck with finding and sorting the leak. I hope your level settles and nothing more complicated is the issue.
Posted 29 December 2024 - 01:20 AM
Have you checked in the car at the pipes to and from the heater, I see you have changed the matrix but is all the piping sound?
Posted 30 December 2024 - 03:03 AM
Most likey the gasket but it could be a cracked head.
Posted 30 December 2024 - 10:25 AM
It could be a porous hose if the leak is small,look at the ends of the hoses for signs of antifreeze when it is cooled.If there are any cloth covered hoses they are prone to this.Just a thought before removing a head which is still not condemned.Steve..
Posted 30 December 2024 - 03:43 PM
How much coolant is it losing?
Posted 31 December 2024 - 11:31 AM
