Minispares Adjustable Timing Gear. Bearing Seal For Dowel Locking Pin?
7 replies to this topic
#1 babsbrown
babsbrown
  • 465 posts
Posted 29 December 2024 - 02:42 PM
Afternoon guys
I'm just timing up my engine and I have the duplex adjustable vernier gear set from mini spares.
It comes with a locking pin that locks the sprocket in place.
Has anyone used or suggest a compound perhaps bearing seal or locktite. That will keep the pin in. It's an interference fit but I don't like relying on just that alone
Thanks, Babs
#2 babsbrown
babsbrown
  • 465 posts
Posted 29 December 2024 - 02:44 PM
Attached File  17354834546748729300016018722313.jpg   32.64K   0 downloads
Edited by babsbrown, 29 December 2024 - 02:45 PM.
#3 babsbrown
babsbrown
  • 465 posts
Posted 29 December 2024 - 02:46 PM
That's not fully inserted. Just a pictorial reference. Cheers
#4 nicklouse
  • 18,587 posts
Posted 29 December 2024 - 03:40 PM
From the instructions.
Ensure you remove peg screw and fit the camshaft lock tab to hold the peg in place.
#5 babsbrown
babsbrown
  • 465 posts
Posted 29 December 2024 - 03:52 PM
Thank you nicklouse.
I guess in this instance I will fold up the locking tab edges on the other sides on the tab and leave the edge covering the pin down.
I have expected a threaded hole with alley key screws like the MED one but guess you pays your money.
#6 nicklouse
  • 18,587 posts
Posted 29 December 2024 - 05:53 PM
A non threaded pin is more accurate. And less likely to cause issues down the line.
#7 babsbrown
babsbrown
  • 465 posts
Posted 29 December 2024 - 10:47 PM
Ah excellent, you learn something new every day. Thanks nicklouse
#8 coopertaz
coopertaz
  • 795 posts
  • Local Club: a-series-magpies
Posted 31 December 2024 - 02:10 PM
had one of these kits on mine and the problem back then was the oil seal leaking, but not sure if they modified the seal surely someone will know, the lock tab is spot on for holding the peg
