Crown Wheel
Nial81
, Dec 30 2024 07:08 PM
4 replies to this topic
Posted 30 December 2024 - 07:08 PM
Is there any difference between a 19/59 and 20/59 crown wheel. I'm changing from 2.9 to 3.1 and wondered if I need to change the crown wheel as well as the pinion.
Posted 30 December 2024 - 07:58 PM
There is a different part number for the 59 tooth crown wheel to suit each different ratio. I can’t imagine they would be interchangeable
https://www.somerfor...ve-differential
Posted 30 December 2024 - 08:00 PM
They are different and not interchangable.
DAM5925 for the 2.9
DAM6327 for the 3.1
Posted 30 December 2024 - 08:29 PM
OK great thanks, I have both was just seeing if I could save swapping as the 20/59 looks slightly better condition.
Posted 31 December 2024 - 02:05 PM
crown wheels are different and will blow main bearing if you use incorrrect one, as i found out years ago! match part number on crown wheel to tooth count on the pinion
Edited by coopertaz, 31 December 2024 - 02:05 PM.
