Steering Wheel Horn Push On A Pre-Mpi Rover Mini
7 replies to this topic
#1 GThomas112
GThomas112
  • 10 posts
Posted 30 December 2024 - 08:39 PM
Hi all,
Has anybody ever had any success fabricating or fitting a slip ring (or similar) setup to wire a steering wheel horn push to a pre-MPi Mini?
I’ve been trawling through old forum posts but to no avail other than knowing the Mk1 steering column had a slip ring for a horn push.
#2 bpirie1000
bpirie1000
  • Area Managers
  • 2,366 posts
  • Local Club: Amoc
Posted 31 December 2024 - 10:40 AM
Anything is possible....
Just depends how much time you have...
Occasionally makes a difference if you have enough money to invest......
#3 mab01uk
mab01uk
  • 12,486 posts
Posted 31 December 2024 - 01:22 PM
Might be worth you asking on the Mk1 Forum.
Also these threads linked below from a quick search on the Mk1 Forum might help.
Horn Push Switch Wiring Assembly BCA 4505?
https://mk1-forum.ne...ic.php?p=129323
Horn wiring question:-
https://mk1-forum.ne...pic.php?p=63307
Edited by mab01uk, 31 December 2024 - 01:24 PM.
#4 GThomas112
GThomas112
  • 10 posts
Posted 02 January 2025 - 09:58 AM
Thanks mab, that's brillaint - I'll see what I can dig out over there!
#5 Spider
  • 15,038 posts
Posted 03 January 2025 - 07:13 PM
On the back-burner for me presently, but I do have it on my list to make a slip ring assy for the later column.
#6 alpder
alpder
  • 441 posts
  • Local Club: MCR
Posted 03 January 2025 - 07:26 PM
Similar topic came up on Mk1 Forum: https://mk1-forum.ne...pic.php?t=39542
ebay item 296477097326 ? (edit: It's a wireless 433MHz remote horn button. Costs a tenner, including the relay. Shouldn't be rocket-engineering to fettle it to fit under the wheel boss.)
Attached File  s-l960.jpg   21.11K   1 downloads
Edited by alpder, 03 January 2025 - 07:42 PM.
#7 Spider
  • 15,038 posts
Posted 03 January 2025 - 07:35 PM
The parts for the MKI won't fit as the later columns are smaller in diameter.
#8 GThomas112
GThomas112
  • 10 posts
Posted 03 January 2025 - 09:14 PM
Ooo that’s a really interesting idea that I wasn’t even aware existed. It looks like there’s a few companies in the UK offering a similar thing, so I’ll do some digging and if I end up with a good solution then I’ll put a post about it together.
Thanks alpder!
