Cleaning Fuel Tank Out With Vinegar
7 replies to this topic
#1 Gaz66
Gaz66
  • 985 posts
Posted 06 January 2025 - 05:41 PM
Has anyone had any success with this method for rust removal?
#2 imack
imack
  • 2,236 posts
Posted 06 January 2025 - 05:47 PM
I've not used vinegar, but I've had success cleaning blocks and heads using citric acid.
#3 mm man
mm man
  • 406 posts
Posted 06 January 2025 - 07:18 PM
I have
A few years ago I visited my local ALDI and purchased a couple of trays of the cheapest bottles of vinegar I could find ( think it was around 26 )
Removed my tank and sender unit then blocked  up all the holes . Chucked in a couple of handfuls of old nuts & bolts then filled it to the rim with vinegar. Left it for a couple of days then gave it a shake up …done this for a couple of weeks then when I emptied it and washed it out it was spotless inside .
I had no issues and I  was  really happy with the results and wouldn’t hesitate to do it again.
Hope this helps but one word of warning don’t use it on your chips afterwards :D  :D
Edited by mm man, 06 January 2025 - 07:19 PM.
#4 nicklouse
  • 18,770 posts
Posted 06 January 2025 - 07:33 PM
Pop down to Screwfix and get a bottle of whatever it is to clean out heating systems.
#5 m1n1
m1n1
  • 769 posts
  • Local Club: I'm unsociable
Posted 06 January 2025 - 09:34 PM
Need to do this myself.   On a series land rover tank i used electrolysis and that worked amazing however i could get my arm through the filler neck and scrub as it worked its magic,  not possible with a saloon tank!   I did clean a few mini bits with brick acid which i believe is hydrochloric and whilst working amazing well its really really dangerous, and flash rust is a problem if not coated in oil immediately after washing it off.        Evaporust looks good.
#6 Gaz66
Gaz66
  • 985 posts
Posted 06 January 2025 - 09:39 PM
That's another problem, stopping the flash rusting after being cleaned as I'll be putting it into storage for a while. 🤔
#7 nicklouse
  • 18,770 posts
Posted 06 January 2025 - 10:35 PM
Have a look at these for internal coatings etc
https://www.frost.co...ch/?q=Fuel tank
#8 Spider
  • 15,254 posts
Posted 07 January 2025 - 06:43 AM
I'd suggest putting a liner through it after. I've had great success with POR15 and KBS Fuel Tank Kits.
