Is there any difference to be taken note of between shimming a helical open diff and a straight cut CW/P equipped LSD?
I can't see that there should be but thought I'd best ask.
Shimming An Lsd/sc/cw/p
Gaz66
, Jan 06 2025 06:18 PM
3 replies to this topic
Posted 06 January 2025 - 06:18 PM
Posted 06 January 2025 - 07:28 PM
I shim them all up the same. It's to preload the bearings and take any shimmy out of them.
Posted 06 January 2025 - 07:34 PM
As above. It’s the bearings you are loading. But what I do do is make sure the CW is nicely positioned on the Pimion.
Posted 06 January 2025 - 07:54 PM
I shim my Quaife atb from the flywheel side to position the crownwheel (MED straight cut) a bit more centrally on the pinion.
