Ported Vacuum Location Question (Slight Oops)
6 replies to this topic
#1 CdnAustinAmerica
CdnAustinAmerica
  • 55 posts
Posted 28 January 2025 - 02:51 AM
I was adding a ported vacuum  location to my HS6 as it was never drilled (after watching Dodd's video advising it)
While I drilled the 3/64 through hole my drill wandered slightly, my fault, and it isn't completely occluded by my throttle plate.
Will this be an issue? Should I plug it and try again in another spot?
#2 DeadSquare
DeadSquare
  • 3,188 posts
Posted 28 January 2025 - 08:22 AM
Yes. Plug it and try harder next time.
#3 68+86auto
68+86auto
  • 1,011 posts
  • Local Club: Queensland Mini Car Club
Posted 28 January 2025 - 09:12 AM
Is it really worth this much effort for ported vacuum?
It makes no difference vs manifold vacuum except at idle.
#4 Ethel
  • 26,073 posts
Posted 28 January 2025 - 03:49 PM
Is that throttle resting on a correctly adjusted idle speed screw? It looks like it might do the job anyway. You want the vacuum to disappear at idle, less advance means less time for trying to push the pistons back where they came from.
You could probably rig up a crude test rig with a vacuum cleaner standing in for a running engine.
#5 Spider
  • 15,136 posts
Posted 28 January 2025 - 05:28 PM
I'd suggest leaving it as you have done it there. It will pull some vacuum at idle, but it will be very very small.
#6 Spider
  • 15,136 posts
Posted 29 January 2025 - 02:51 AM
If you go to post #18 in this thread;-
https://www.theminif...dvance-fitting/
You'll see that the throttle needs to be open aways before any vacuum is pulled from the ported vacuum take off, hence why I suggest where you have yours now will be fine.
#7 CdnAustinAmerica
CdnAustinAmerica
  • 55 posts
Posted 29 January 2025 - 03:50 PM
Thanks Spider! That's some useful info, I'll hopefully have time to confirm that myself soon.
