Is there really any need to drill and tap the block to 5/16 unf for the gearbox to block bolts on a competition engine?
Anyone had any trouble with the 1/4 unf bolts?
Edited by Gaz66, 28 January 2025 - 05:16 PM.
Posted 28 January 2025 - 05:15 PM
Posted 28 January 2025 - 05:18 PM
Edited by imack, 28 January 2025 - 05:20 PM.
Posted 28 January 2025 - 05:26 PM
I've never found the need to go bigger than the original 1/4"UNF Screws.
Posted 28 January 2025 - 05:34 PM
I've always drilled and tapped for 5/16" unf bots. Whether it makes any difference, I've no idea.
5/16 bolts are a faff to get a spanner or allen key onto.
Posted 28 January 2025 - 07:36 PM
Did it as I had the time and the kit.
keeping original and using Allen head sockets could make life easier.
i can think of better things like a hole in the subframe so you can get all the Wok bolts.
Posted 28 January 2025 - 09:27 PM
I have never used anything other than the original 1/4" bolts even on 100+ bhp competition engines.
There has never been any issue with the 1/4" bolts, so why try to fix a problem which doesn't exist.
Edited by Cooperman, 28 January 2025 - 09:29 PM.
Posted 28 January 2025 - 10:32 PM
Posted 28 January 2025 - 11:31 PM
The only force separating the block from the gearbox comes from the transfer gears, and the transfer case straps them together, so why weaken the aluminium casing by enlarging the holes ?
Posted 29 January 2025 - 10:52 AM
