my 998 metro is burning up points in about 2000miles with this setup, but why?
it has the following setup lucas 45d, new condenser, new points adjusted to about 0.015", several different 1.5ohm coils both new and used, ballasted ignition when running, full voltage when cranking (as a normal metro with pre-engaged starter), measures 11 dc volt with engine running, tried a new wire with a new ballast resistor, good cables and plugs.
so why is it burning up new points so quickly? they are bubbling up in the center? what am I missing?
I have now changed to the cheap minispares electronic dizzy but I would still like to know whats wrong with it.
Edited by dotmatrix, 28 January 2025 - 09:34 PM.
