If I can suggest if you are doing this kind of a build, work to Dynamic Compression Ratios are I feel they are WAY more relevant than just (Static) Compression Ratios.
I start this by establish what Octane fuel is being used, then Street or Track use, then looking at the Cam and it's characteristics and how I'd time that in to place the power band where I feel it needs to be.
I work to 8.4:1 DCR for the street and 8.6:1 DCR for the track, these are both on Iron Heads and is a little higher for Alloy.. While these numbers to someone who used to working with SCRs may appear low, the 60's Cooper S has a DCR of 8.4:1 and a SCR of 9.75:1.
The longer the duration of the Cam, the more SCR you need to end up with.
<EDIT: The DCR Numbers I've given here are for 97 Octane Fuels >
Edited by Spider, 12 February 2025 - 08:21 PM.
