Clutch Cover Removal While In Car
9 replies to this topic
#1 maccers
maccers
  • 1,868 posts
  • Local Club: LSMOC
Posted 13 February 2025 - 04:23 PM
As above, I have the easy bolts out, and have read to remove the bolts on the engine mount, and lift the engine a bit. Is this to allow access from the underside or top of engine bay? As the jack will get right in my way from under...!
#2 Steve220
Steve220
  • 5,045 posts
  • Local Club: BMC
Posted 13 February 2025 - 05:41 PM
You need to lift it to get the wok out from above.
#3 maccers
maccers
  • 1,868 posts
  • Local Club: LSMOC
Posted 13 February 2025 - 05:47 PM
Yep, I still have 2 bolts right at the bottom that seem to be inaccessible, the Haynes book says to remove the mount and jack up engine a bit to gain access. I was wandering if access to undo the bolts is from the top or bottom of car. Its going to be awkward whatever I think!!
#4 DeadSquare
DeadSquare
  • 3,106 posts
Posted 13 February 2025 - 05:51 PM
65 years ago, I drove the front wheels up onto two car ramps.
Put a 6 foot length of scaffold board under the sump and chocked it up, under the footwell, then lifted the end in front of the car and rolled a log under it with my foot.
#5 gaspen
gaspen
  • 946 posts
Posted 13 February 2025 - 06:26 PM
Get a "flexible" rachet
Attached File  51O6YsivZDL.jpg   24.92K   0 downloads
#6 Shooter63
Shooter63
  • 1,034 posts
Posted 13 February 2025 - 06:38 PM
Presuming that you are talking about the 6 and 7 o'clock bolts, then I used to drill a hole through the subframe in the right places big enough to get a 3/8 drive socket through. And if I'm being honest again I will do the same on my MK1 when I change the engine this year, saves all the agro. If you are doing a clutch change in car a lot of people just leave the 7 o'clock bolt out.
Shooter
#7 nicklouse
  • 18,593 posts
Posted 13 February 2025 - 07:48 PM
Bend a spanner to fit.
#8 imack
imack
  • 2,110 posts
Posted 13 February 2025 - 08:03 PM
I remove all bolts from on top, except for the one in the 6 o'clock position. Remove the two engine mount bolts from the subframe, (you may need to disconnect the upper and lower stabilisers if fitted too) jack the engine up an inch or so and use the ring end of a combination spanner on the bottom bolt. Sometimes easier to get the spanner up between the battery cable and the subframe to get the spanner more squarely on the bolt head. Crack the bolt off and wind it out with your finger tips.
Edited by imack, 13 February 2025 - 08:51 PM.
#9 Steam
Steam
  • 763 posts
  • Local Club: Victorian Mini Club
Posted 14 February 2025 - 01:52 AM
And once it is out do not refit it. You be glad the next t8me you have to remove the cover.
#10 Steve220
Steve220
  • 5,045 posts
  • Local Club: BMC
Posted 14 February 2025 - 01:21 PM
Those are a nightmare!! I bent a spanner 🤣
