Rear Bearings Shim
7 replies to this topic
#1 Manb2ndb
Manb2ndb
  • 44 posts
Posted 23 February 2025 - 10:44 AM
Hi, I’m in the process of fitting new timken bearings into a new rear hub, all Minispares.
The timken bearing comes with a little shim, which I assume sits on the outer face of the inner hub shoulder. A piece of paper says you must measure the shoulder to see if it’s needed. Problem is I don’t have any calipers or micrometer that fits?
Is it a case I fit without shim and if wheel is tight? If it is tight I then rebuild with the shim? Or from experience does anyone know of they are needed on new hubs?
#2 andyapanel
andyapanel
  • 625 posts
Posted 23 February 2025 - 10:48 AM
I think there was some discussion of this fairly recently.
I can’t remember what the upshot was , but a search should find it.
#3 68+86auto
68+86auto
  • 984 posts
  • Local Club: Queensland Mini Car Club
Posted 23 February 2025 - 11:03 AM
Most likely you don't need the shim.
#4 Manb2ndb
Manb2ndb
  • 44 posts
Posted 23 February 2025 - 11:09 AM
I did have a search, I got confused with it, as they were talking about existing old hubs
My thoughts are that it’s not needed but wanted to save me taking them back out
#5 MatthewsDad
MatthewsDad
  • 819 posts
Posted 23 February 2025 - 11:10 AM
I think this is the recent thread...
https://www.theminif...m/?fromsearch=1
#6 Manb2ndb
Manb2ndb
  • 44 posts
Posted 23 February 2025 - 11:27 AM
Ah yes, thanks
So it comes down to what hub you have? Being anew one maybe won’t have an issue?
#7 Manb2ndb
Manb2ndb
  • 44 posts
Posted 23 February 2025 - 02:50 PM
I’ve found a pic of genuine rover hub (which need the shim) is the same pic as mini spares hub pic. I’m going to add shim and see how I get on
#8 gav
gav
  • 700 posts
Posted 24 February 2025 - 09:27 AM
Yes to clarify you will need to use the shim on those new hubs.
