1993 SPI Mini Cooper which is completely factory original.
Both my full beams do not work on either flash or full beam setting:
I have checked both fuses and they are fine with 12V at them.
The blue and white bullet connections at the slam panel do not have 12V
The spotlights come on as normal with full beam on.
i can make the full beam come on if I switch the bullet connector to the side lights. So it’s not the bulb.
Very very strange that both have stopped working…running out of ideas. Fuses are fine and have 12v. And bulbs are fine. Strange.
Advice appreciated!!
