Mini Spares Stage 2 Lcb
7 replies to this topic
#1 cotty
cotty
  • 60 posts
Posted 25 February 2025 - 12:03 PM
hi guys has anybody had fitting problems ?
#2 nicklouse
  • 18,662 posts
Posted 25 February 2025 - 01:04 PM
Like what?
#3 cotty
cotty
  • 60 posts
Posted 26 February 2025 - 09:36 AM
the lcb is up against the pot joint and diff case also the exit is not central to the tunnel ?
#4 KTS
KTS
  • 2,455 posts
Posted 26 February 2025 - 04:02 PM
is the manifold square against the cylinder head face and nuts tightened ?
the LCB is offset to the tunnel to allow the exhaust to get past the remote gear housing (edit: that's a maniflow LCB)
Edited by KTS, 26 February 2025 - 04:05 PM.
#5 maccers
maccers
  • 1,875 posts
  • Local Club: LSMOC
Posted 26 February 2025 - 06:34 PM
Whats the o2 sensor for? Are you running a forced induction? Only asking as mines supercharged and the o2 sensor is higher up on the branch of the LCB that connects to the readout/ecu.
#6 KTS
KTS
  • 2,455 posts
Posted 27 February 2025 - 05:34 PM
sensor is for a wideband AFR gauge - install instructions recommended fitting it 18" away from the exhaust ports
#7 timmy850
timmy850
  • 3,376 posts
  • Local Club: MITG
Posted 27 February 2025 - 09:04 PM
Having it on the collector means it gives an average of all 4 cylinders
If it’s higher up it may be in either the inner cylinder pipe or the outer cylinder pipe. These will often show slightly different mixtures due to the Siamese ports firing order and fuel distribution normally favouring the inner cylinders (and the inners showing richer).
I suppose there is a good reason to only sample off the leaner outer cylinders, as having them spot on and the inners a little richer is probably better than the inners spot on and outers a bit lean
#8 imack
imack
  • 2,184 posts
Posted 28 February 2025 - 01:32 PM
I thought it was the other way around, 1&4 rich and 2&3 leaner?
