Alloy Wheels And Spacers
6 replies to this topic
#1 germini30
germini30
  • 722 posts
Posted 28 February 2025 - 11:57 AM
I'm going to fit 10 inch wheels to my 1989 mini 30, I know I need to get the conversion kit for the brakes first.
Regarding the wheel, I'm looking at JBW minilight in the 5x10 offset 12.
My car currently has 5 x 12s with offset of 14, so the JBW wheels will sit out 2mm further.
I have group 2 arches, narrow type, and the front wheels sit nicely under the arches but the rears could do with sitting out a bit more, in my opinion.
I don't want 6 x 10 as they'll stick out loads.
Can I fit the 5x10 and use say a 8-10mm spacer on the rears if I like or is that not a good option?
Any feedback is appreciated.
#2 nicklouse
  • 18,998 posts
Posted 28 February 2025 - 12:30 PM
I would be more concerned about what tyres you plan to use as that will give the same result whatever rim you use.
#3 germini30
germini30
  • 722 posts
Posted 28 February 2025 - 01:18 PM
165 70 10 yoko
#4 nicklouse
  • 18,998 posts
Posted 28 February 2025 - 01:54 PM
Put your specs into this https://www.willtheyfit.com/ and compare.
5 or 6s will have the same result on the 10s, Just a slight difference in sidewall shape.
#5 germini30
germini30
  • 722 posts
Posted 28 February 2025 - 02:04 PM
The 6 x 10 wheel has an offset of minus 7. They'd stick out 33mm more than my current wheels
#6 mab01uk
mab01uk
  • 12,925 posts
Posted 28 February 2025 - 03:05 PM
8-10mm thick spacers on the rear are not a problem as long as you also fit suitable length longer studs where required. Probably best to buy and fit the 5 x 10 wheels/tyres you want and once they are on the car you can decide exactly what the nearest thickness of available spacers will achieve your desired look.
Minispares Spacers /studs:-
https://www.minispar...31/3101/310104/
#7 germini30
germini30
  • 722 posts
Posted 01 March 2025 - 07:48 PM
Yes probably the best approach.
My current 5x12 with 14 offset the 165 60 12 tyred sit just proud of my front group 2 arches, rears are just inside. If I go for 5 x10 with 12 or 14 offset they'll sit around the same I guess
