I know the topic of play in the front wheels/hubs have been covered many times, I'm not sure if my issue is similar enough...
With the car on the ground, I happened to just check the wheels for play after having driven a bit since the rebuild.
The driver's side front wheel had slight movement when holding the top of the tyre and rocking side to side. It felt like a small amount of movement that had a noticeable 'click'.
I jacked the side up and tried to see if there's 3/9 o'clock movement and there is none.
Tried 6/12 o'clock and there was none. Rotated the wheel and noticed at some point there is 6/12 o'clock movement. I checked for movement at the ball joints but didn't see or feel any. Lowered the car and again the play was gone so I moved the car forward and back and at a certain point there is that slight play when rocking side to side as before. Moved the car further forward and that play was gone.
But, then at 3/6 o'clock I heard a knock/louder click when rocking side to side that way but couldn't see any movement. This only happened on this one occassion. I was not able to get this again after moving the car forward and backwards a few times.
So, since everything is new, except the wheel bearings (which seemed good), CV's and ball joints and the fact that it's got that play at a certain point in the wheel rotation, am I right in thinking the issue is likely the wheel bearings? Either worn or not in properly or hub nut not tightened up properly?
I can't think what else to check. I should also say that the CV makes a cluck cluck noise when turning at full lock so that is definately in need of replacement but I don't think that can cause the kind of play I'm feeling on the wheel?
