Could someone please check my calculations are right?
I'm pre loading the diff.
Basically I have measured my side case with no shims and I have no gap.
I've measured My gasket and it's 15 tho.
I have the steel bearing needing 2 thou pre load (KSM)
With shims I have got the gap to 17 thou
Is this correct? Indicating a 2 thou preload?
As the gasket would take up 15 thou, then I'm left with 2 tho of shim pushing on the bearing?
Thanks in advance, Luke
Edited by babsbrown, 05 March 2025 - 12:32 PM.
