Problem Starting Up My Mini Balmoral 1.3I Of 1996
4 replies to this topic
#1 BobCosta
BobCosta
    Starting My Mini Up
  • 2 posts
Posted 05 March 2025 - 03:03 PM
Hello Everyone,
I own a MINI Rover Balmoral 1.3 I of 1996
It has a problem and hope someone will help me;  it does not start up. When my mechanic pours few drops of  fuel in the throttle body where the injector is located the car starts up normally and can drive, but when the engine is cold (after say 1 hour) it does not start up !
I guess to find the fault a diagnosis is necessary by means of a software to connect the car to computer (I have already bought the cable on eBay)
I have already download the Rover MEMS 1.3/1.6 Fault Code Reader for MAc/Apple.
My question is: if I link my car via cable to the software (Rover MEMS 1.3/1.6 Fault Code Reader) will I be able to get code for the fault?  do I need anything else?
Pardon my ignorance but I am not an expert on this field.
I'd appreciate your suggestion to solve the issue with my MINI, this occurred as a result of a stormy weather with heavy rain. The car was running and starting up normally, the next day after the storm it stopped working
Your tips and replies very much appreciated
Kind Regards
Bob
#2 mab01uk
mab01uk
  • 12,515 posts
Posted 05 March 2025 - 10:36 PM
I posted this article linked below a while back which might be worth a read.
Mini Mpi Diagnostics - Car Mechanics Magazine:-
https://www.theminif...zine/?p=1171123
The full article attached scanned in PDF for Diagnostics tracing and fixing common faults on the MEMS 2J (Modular Engine Management System) fitted to all MPI (Multi-Point Injection) Minis:-
https://www.theminif...azine/?p=941375
Edited by mab01uk, 05 March 2025 - 10:39 PM.
#3 hungdynasty
hungdynasty
  • 175 posts
Posted 06 March 2025 - 03:42 AM
You will get fault codes of following from Rovermems app, some of them just OK by default.
Attached File  Screenshot_2025-03-06-11-37-59-588_com.jmp.rovermems.jpg   20.12K   1 downloads
#4 68+86auto
68+86auto
  • 1,001 posts
  • Local Club: Queensland Mini Car Club
Posted 06 March 2025 - 11:44 AM
As far as I'm concerned, MEMS is not required. Check the voltage at the starter when cranking. If it's below 9.6v there will be issues. A mini should however read much higher than 9.6v due to the large battery size compared to the engine size.
#5 genpop
genpop
  • 530 posts
Posted 09 March 2025 - 07:02 AM
check the dizzy  and ignition cables on moisture
if its a mpi i speak about the ignition coil block.of course
Edited by genpop, 09 March 2025 - 09:00 AM.
