Dti And Magnetic Stand
8 replies to this topic
#1 Gaz66
Gaz66
  • 963 posts
Posted 08 March 2025 - 01:23 PM
Can anyone recommend a good one?
I've just received one from eBay and when the dial is zeroed and the plunger depressed the gauge returns to any random number except zero 😳
So that's on its way back!
#2 KTS
KTS
  • 2,465 posts
Posted 08 March 2025 - 01:44 PM
I'd start with a reputable seller, someone like H Roberts and sons, and have a look at what they stock at the cheaper end of their range
https://www.hroberts-di.com/
i'd recommend getting a DTI extension piece (4"/100mm) at the same time as they come in handy for some jobs
#3 Gaz66
Gaz66
  • 963 posts
Posted 08 March 2025 - 01:51 PM
Wow, I never knew you could spend so much money to find TDC 😁
#4 Stevie W
Stevie W
  • 1,204 posts
  • Local Club: P&SMOC
Posted 08 March 2025 - 05:39 PM
From memory, Machine Mart do a good quality item.
Cheers, Steve.
#5 Shooter63
Shooter63
  • 1,084 posts
Posted 08 March 2025 - 05:46 PM
While the one you have sounds like a POS, I can't think of a reason you need or want to start from an open zero setting.I always put a bit of load on and move the dial round to zero, or if you go for a fancy dan LCD version they have a zero button. A good solid stand makes a world of difference.
Shooter
#6 Gaz66
Gaz66
  • 963 posts
Posted 08 March 2025 - 06:06 PM
Cheers, Steve.
Just been looking at those 👍
#7 Gaz66
Gaz66
  • 963 posts
Posted 08 March 2025 - 07:04 PM
Shooter
I agree with what your saying shooter. I never even got to use it on a job just the initial unboxing and playing with set the tone of the whole shaboodle!
A closer look shows the plunger is binding in the case on return which explains the random numbers.
#8 Spider
  • 15,176 posts
Posted 08 March 2025 - 07:27 PM
Starett or Mitutoyo.
Some may say they are 'dear' but I would disagree. Even for the guy at home, you need instruments and measuring gear you can rely on and trust, otherwise, it leads to expensive and time consuming mistakes. I've had the frustration of trying cheaper gear, which wasn't that much cheaper.
#9 Avtovaz
Avtovaz
  • 1,267 posts
Posted 08 March 2025 - 11:42 PM
funny as im trying to measure the tappet clearences on my b230 engine, and its not easy... ill give the head to someone else to do
