Coil Too Hot?
5 replies to this topic
#1 CdnAustinAmerica
CdnAustinAmerica
  • 55 posts
Posted 10 March 2025 - 01:35 AM
I had a powerspark module fail recently so I swapped in a different dizzy with accuspark on it and it ran great, I think there was a problem with my module before it failed, ran it for about 10-15 minutes so I could set the timing correctly for now, just 10 bdtc at 1k rpm.
I checked the coil and it was hot enough that I couldn't rest my hand on it for more than a second or so, this was after 10 minutes running.
Is this alright for just idling it?
Car was originally a ballasted system which I bypassed as it was causing an issue a while back. It has a GCL143 that only has a few hours on it - 0.9 ohm coil.
#2 timmy850
timmy850
  • 3,386 posts
  • Local Club: MITG
Posted 10 March 2025 - 05:53 AM
What ignition module is it?
Running a 0.9ohm coil needs a specific module with variable dwell. If the dwell time is too long it’ll overheat the coil
#3 CdnAustinAmerica
CdnAustinAmerica
  • 55 posts
Posted 11 March 2025 - 02:43 AM
Its an accuspark "stealth"
Edit: I just looked, I didn't know about that, it says to fit only a 1.5 ohm or 3 ohm with their module, I'll have to go find my original lucas coil and swap to it. Thanks for that info, I wasn't aware of that being an issue with these!
Edited by CdnAustinAmerica, 11 March 2025 - 02:47 AM.
#4 CdnAustinAmerica
CdnAustinAmerica
  • 55 posts
Posted 13 March 2025 - 03:00 AM
So the accuspark says it needs at least 1.4 ohms to run properly, can I run it on a 1.5 ohm coil -without-the ballast wire? its been bypassed.
Or should I add a ceramic one? If so how should I wire it up?
#5 timmy850
timmy850
  • 3,386 posts
  • Local Club: MITG
Posted 13 March 2025 - 04:28 AM
A 1.5 ohm coil running 12V should work according to their instructions
If you were using a ballast resistor and the 1.5 ohm coil you would need to make sure that the module gets 12V and the coil gets the ballast voltage
However if the module provides a variable dwell and is capable of running a 1.5 ohm coil at 12V that will give a better spark
I have one of the Accuspark modules and when I’ve checked the dwell it’s about 20-25 degrees at idle and increases with rpm, so at least the one I bought is variable dwell.
Edited by timmy850, 13 March 2025 - 04:30 AM.
#6 CdnAustinAmerica
CdnAustinAmerica
  • 55 posts
Posted 13 March 2025 - 06:11 AM
Thats good to hear, hopefully mine is the same, hopefully I didn't harm the module running it for 10 minutes with the 0.9 ohm coil...
I'll be running a high power powerspark module + coil soon so I'd rather leave it bypassed but I do have a generic ceramic one just in case. I emailed accuspark for info but they haven't responded and i can't find specific technical info/specs on their website.
Edited by CdnAustinAmerica, 13 March 2025 - 06:15 AM.
