Body Twisted/too Long Between Subframe Mounts
2 replies to this topic
#1 CallumAustin11
CallumAustin11
  • 27 posts
Posted 16 March 2025 - 07:41 PM
Hi there,
I am in the process of completely replacing the entire floor along with toe board, boot floor and rear arches.
I have created a jig for this and just going through the measurements now to ensure everything is correct. I have measured from the front subframe tower bolt to the rear subframe boot floor mount (rear most hole) to be 2300mm exact.
Using pre existing dimensions I found on a drawing on another forum post. It says that measurement should be 2278mm. 20mm difference.
Should I be worried?
Many thanks
#2 gaspen
gaspen
  • 948 posts
Posted 16 March 2025 - 07:54 PM
Did you measure from-point-to-point or projected to the horizontal plane ?
If you want check symmetry it is a good idea to measure diagonals.
Attached File  22218510139cede138ce5a67f6e70f76b4ea4a76.jpg   35.73K   2 downloads
#3 CallumAustin11
CallumAustin11
  • 27 posts
Posted 16 March 2025 - 08:02 PM
I measured level with the rear subframe mount
