Hif44 Turbo Carb For Na?
Posted 12 April 2025 - 08:29 AM
As above, some time ago I bought a HIF44 carb from a chap who was breaking up a turbo engine setup. At the time I didn’t even realise there was a difference between the turbo and NA carbs.
After a lot of forum digging I can see NA carbs converted to be used on turbo applications but not the other way round.
Obvious question - can a turbo carb be used in a NA setup? Or best to sell the carb/exchange with a NA version?
Posted 12 April 2025 - 09:51 AM
Just use it*, turbo engines aren't always making boost .
*with the usual steps to get fuel metering matched to the engine.
Posted 12 April 2025 - 11:54 AM
Posted 12 April 2025 - 01:45 PM
No.
It's how it's vented that matters most on boost. Turbo carbs have a port, through the casket, to the plenum (filter housing on NA). There's also an external hose connection that was closed by a solenoid valve on the factory turbo cars. You could leave open.
You might have more fun from the part throttle leaning device - that black curvy hose that loops to in front of the dashpot. It can just be blocked off if you do.
