Flywheel Housing Bolt Locations
4 replies to this topic
#1 orac69
orac69
  • 107 posts
Posted 05 May 2025 - 01:31 PM
Hi, been searching for ages, can't seem to find an answer to this one.
Still putting back together an A+ 998 from a box of bits. I didn't take it to bits... I've rebuilt the gearbox using Guesswork kit, have bolted it back to the lump and now I'm on to the flywheel housing.
Is there a picture or guide to which size / threat type bolts to use in which hole, and if to use washers/spring washers and thread lock? All the vids, rebuild guides just show bolts being put in, but not what sizes where - and there must be a dozen or more holes...
I want to do it right first time, thanks!
Edited by orac69, 05 May 2025 - 01:33 PM.
#2 nicklouse
  • 18,697 posts
Posted 05 May 2025 - 01:34 PM
First off. UNC into the box. UNF into the block.
spring washers are fine.
should not be hard to work out which are long and which are short.
#3 orac69
orac69
  • 107 posts
Posted 05 May 2025 - 01:46 PM
Thanks, trying to work out what to order as I don't have any bolts for this. Mini spares is confusing, studs, no studs, flanged, not flanged etc.
#4 Spider
  • 15,144 posts
Posted 05 May 2025 - 07:49 PM
The early boxes up to about 1984 had studs in the Gearbox Case. After that time, they went t a UNC Flanged Bolt here.
#5 orac69
orac69
  • 107 posts
Posted 06 May 2025 - 03:48 PM
Sorted, thanks guys
