Interior Controls, Switches, Knobs, Levers...
3 replies to this topic
#1 edmax
edmax
    Starting My Mini Up
  • 1 posts
Posted 05 May 2025 - 03:31 PM
Hi All,
My first post here. I have a 1967 Innocenti "Mini Minor" and am a bit baffled by the function of some of the controls. Does anybody happen to have a page from an owners manual or some such that explains everything? I certainly know the Choke well and also the windscreen wiper switch. But what are the others? Two switches below the instrument cluster? A switch on the bottom of the box that controls the "fresh air" intake, the levers on the steering column (one is a turn signal but not sure about others). I've searched the forum and found bits and pieces but nothing that really helps.
Thanks all
Regards,
EDMax
#2 unburntfuelinthemorning
  • 1,991 posts
Posted 19 May 2025 - 11:23 AM
Are you able to post a photo of your particular setup?
#3 bluequinn
bluequinn
  • 105 posts
Posted 19 May 2025 - 03:24 PM
There are a load of Innocenti manuals here: https://www.registro...li-e-cataloghi/
Some italian translation will be necessary, but you should be able to fill in all the gaps.
The two column stalks are for indicators and lights.
#4 cockney21
cockney21
  • 24 posts
Posted 04 June 2025 - 08:58 AM
Not sure if the same as mine, I've got a 1974 1300 Cooper Export. Main lighting rocker switch turns on side lights, then a stalk below the indicator one turns headlights from side/low beam/main beam, instrument lights has another switch to turn on/off.
