Flywheel Bolt Too Short - Arrgh.
4 replies to this topic
#1 orac69
orac69
  • 95 posts
Posted Yesterday, 07:55 AM
Hello,  rebuilding an A+ pre-verto from a box of assorted bits (un)kindly provided by the PO.
Thought I was getting somewhere, thanks to your help here - shout out to nicklouse and spider by the way...
Anyways, ive put the clutch / flywheel / friction plate in, lined it all up, put the keyway, washer and flywheel bolt in and it only just "catches" on the threads.  I took everything out, realligned it all, put it back, same issue.  Head scratching..
Ive come to the conclusion my bolt is too short!   The total thread length is only about 3/4" (or only about 8 or 9 threads).  Checking out somerford or minispares catalogue (the actual length of the bolt isnt given), but from the photos it looks like there should be 15 or so threads - so it obviously goes into / grabs more in the tail.
Seem odd to anyone?  Or were the original factory ones just this short...
Edited by orac69, Yesterday, 08:03 AM.
#2 Gaz66
Gaz66
  • 908 posts
Posted Yesterday, 08:37 AM
That's the wrong bolt. That's the bottom pulley bolt.
https://www.minispar...-bolt-pre-verto
Edited by Gaz66, Yesterday, 09:06 AM.
#3 nicklouse
  • 18,593 posts
Posted Yesterday, 08:51 AM
As above. Wrong bolt.
#4 orac69
orac69
  • 95 posts
Posted Yesterday, 09:12 AM
Doh! Don't I feel stupid.
...and really odd as there are 2 of those bolts in the box of bits.
In my defence, I haven't done the other end, I assumed it's the same bolt each end.
Edited by orac69, Yesterday, 09:13 AM.
#5 Gaz66
Gaz66
  • 908 posts
Posted Yesterday, 11:31 AM
The bolt you've shown there is the opposite end of the crank, for the bottom pulley.
The minispares link I put in my first post is the flywheel bolt you require.
