Hello
I have two M35J starter motors which I would like to save. As you can see the insulation on the field coil gone with the wind :)
My idea that I will using PTFE tape for insulation. Is it suitable for this purpose ?
Also the rear end of the shaft is worn. I have bush kits to replace but the shaft end will wobble in the new bush
Is it better to weld up the shaft and turn / grind to size ? Or use a smaller bush ? I can find similar bushes with metric sizes
20250508_103929.jpg 45.83K
0 downloads
20250418_160118.jpg 39.71K
0 downloads
