Info Needed - 1071 Cooper S Engine
Posted 17 May 2025 - 09:32 AM
Shooter
Posted 17 May 2025 - 10:27 AM
There were probably a few things at play, the 970 is listed as a 9.75:1 compression ratio and the 1071 only 9:1
The 970 also had the airbox and alloy elbows, generally the longer the length pre-carb the better the low down torque will be
They were also given significantly different amounts of timing, nearly 10 degrees more on the 970 which would have increased low down performance
The other thing is it could have been a typo and carried through in all the brochures. You'll notice it also lists the ignition system as having "vacuum control" which it clearly didn't have
Edited by timmy850, 17 May 2025 - 10:28 AM.
Posted 17 May 2025 - 10:59 AM
The S engines vary in stroke, not bore. The same cylinder pressure on the same piston area will give the same force, but a longer crank will create more torque from it. The flip side is the piston acceleration & maximum velocity also increases with the stroke
The compression ratios were likely for different grades of fuel. As we know, all the S's were built for race homologation & are a rebore away from a class engine capacity limit.
Posted 17 May 2025 - 09:16 PM
If you go to this thread, post #25;-
https://www.theminif...-rubbish/page-2
You'll get the numbers from the horse's mouth
Posted 18 May 2025 - 11:08 AM
Cheers mate.
Shooter
