Gas And Oil
5 replies to this topic
#1 Medusa
Medusa
  • 48 posts
Posted 17 May 2025 - 06:42 PM
What gas and oil are you guys putting into these 1275 engines?
Premium gas and 10-40 synthetic oil?
#2 lippo
lippo
  • 144 posts
Posted 17 May 2025 - 07:39 PM
 We have different levels of petrol in the UK - I stick 95 RON unleaded (91 octane equivalent) in the car and use lead substitute.
 20/50 mineral is the oil to use, don't use synthetic in an A Series.
#3 timmy850
timmy850
  • 3,386 posts
  • Local Club: MITG
Posted 20 May 2025 - 10:39 AM
The owners manual dated 1999 says:
95 RON fuel
10W/30 oil
https://www.uscars.b...CD_hr01795e.pdf
#4 nicklouse
  • 18,696 posts
Posted 20 May 2025 - 01:26 PM
What gearbox is important as well.
you don’t want 20-50 in an auto.
#5 brivinci
brivinci
  • 1,210 posts
Posted 20 May 2025 - 03:09 PM
If you search this question you will find many MANY threads on it.
Being that you are in the injection forum, I alum your car was meant to use unleaded fuel, so no need to add lead. Go with a higher octane.
For oil, 20/50 and I am assuming you have a manual. This has been discussed over and over. The owners manual should be ignored on this. My personal recommendation for oil is Driven GP-1 20/50. This was recommended by engine builder/tuner Keith Calver awhile ago when I rebuilt my 1275 (now 1310) SPi. I recently had the motor out and took the opportunity to go through it all and see how it was fairing as I needed to have a flywheel balanced and machinist needed the crank. He actually asked what oil I was using as the bearings looked mint after 25k. Not that they shouldn't but he said stick with whatever you are using as its clearly quality.
The key is to ensure the oil you use has the correct amount if zinc (ZDDP). This is essential for all push rod/flat tappet motors. If not, you will wear down your cam.
#6 NLinPEN
NLinPEN
  • 101 posts
Posted 22 May 2025 - 05:39 AM
Does your car have an automatic gearbox? If so, do NOT use regular car engine oil. The engine, automatic gearbox, and clutch share the same oil. You need oil intended for motor bikes. The reason is that your clutch is of the wet-clutch type. Motor bike oil has special properties for this type of clutch.
