Mpi Rebuild. Wiring
2 replies to this topic
#1 pete l
pete l
  • 1,371 posts
Posted Today, 01:55 PM
Hi all,
Building my MPI back up, putting in the wiring harness. With the 3 wires going up to the interior light there is a single red wire with a spade connector on the end. Does anyone know what it's for ?
Pete
#2 Steve220
Steve220
  • 5,051 posts
  • Local Club: BMC
Posted Today, 07:28 PM
It's for the electric sunroof if you have one fitted.
#3 weef
weef
  • 495 posts
Posted Today, 08:44 PM
I believe the feed for the electric sunroof comes from the passenger compartment fusebox, fuse B7.
If I am correct the other end of this wire will be there and a quick continuity check will confirm.
If there is no sunroof you can either connect the wire at the fusebox, to keep things tidy, and leave the fuse out or you could tape the wire back to the harness out of harms way.
