1999 Rover Mini Mpi Misfiring And Loss Of Power
7 replies to this topic
#1 hsamy
hsamy
    Starting My Mini Up
  • 1 posts
Posted 20 May 2025 - 09:43 AM
Hi everyone, i am new to this forum and have a problem with my 1999 Rover Mini MPI. The car is in Dubai and it came from Germany so i purchased it about a year ago and have been having many issues with it since then. The most recent one is misfiring in cylinders 2 and 4 according to my mechanic. We changed almost everything; spark plugs, wires, coil, the entire throttle body assembly, and have come to the conclusion that the ECU is faulty. I am told that the injectors are not spraying fuel consistently. Can someone please advise what to look for given this description of the issue? Thanks
#2 sonscar
sonscar
  • 3,036 posts
Posted 20 May 2025 - 10:12 AM
Vacuum pipes,fuel trap,fuel filter spring to mind.cyls 1&2 use the same injector as do 3&4.cam sensor faulty?just thoughts
You have checked engine health,compression,valve clearance manifold leaks,Steve..
#3 68+86auto
68+86auto
  • 995 posts
  • Local Club: Queensland Mini Car Club
Posted 20 May 2025 - 10:27 AM
Get a mechanic with an oscilloscope to have a look. It can then easily be determined if it is an injector issue vs ignition issue and what is the cause.
Edited by 68+86auto, 20 May 2025 - 10:27 AM.
#4 Ethel
  • 26,057 posts
Posted 20 May 2025 - 11:34 AM
I wondered if it had been plugged into a scope & they didn't realise the MPI has asymmetric injection for the siamese ports.
It does seem unlikely to be the ecu if it's firing at all.
#5 Fast Ivan
Fast Ivan
  • 2,910 posts
Posted 20 May 2025 - 01:14 PM
Have they established if there is or isn't sparks coming from each of the leads? Have they done a compression test and do they have the results?
If they're content to just swap things out then there's the crank and cam sensors left to go
#6 alpder
alpder
  • 444 posts
  • Local Club: MCR
Posted 20 May 2025 - 03:24 PM
I had an '80s Ford EFi give trouble recently - stuttering on acceleration, low on power at top end. I figured injectors and changed them for recon. Didn't help. So changed *everything* else, one by one. Having finally ruled out absolutely every other possible cause, I finally trusted my original instincts and bought a set of NOS injectors: problem solved. The "recon" injectors went back. With a strongly-worded note. I now have a shed full of Ford EFi spares.
You haven't mentioned swapping-out injectors. Being mechanical parts they tend to fade-out slowly, rather than die suddenly and completely. So for a "still running but badly" situation, they're surely high on the list of possible causes once ignition is ruled out. Of course, could be something dead simple: clogged fuel filter or fuel line, say.
Edited by alpder, 20 May 2025 - 03:24 PM.
#7 bpirie1000
bpirie1000
  • Area Managers
  • 2,370 posts
  • Local Club: Amoc
Posted 20 May 2025 - 04:35 PM
Have been some very questionable leads going about lately....
Maybe change to old ones or switch the leads se if fault follows..
#8 mab01uk
mab01uk
  • 12,514 posts
Posted 20 May 2025 - 10:35 PM
See link below for diagnostics tracing and fixing common faults on the MEMS 2J (Modular Engine Management System) fitted to all MPi (Multi-Point Injection) Minis.
Mini MPi Diagnostics - Car Mechanics Magazine (June 1999) :-
https://www.theminif...anics-magazine/
Edited by mab01uk, 20 May 2025 - 10:37 PM.
