I own a 1985 mini city 1000, which i am restoring, can anyone tell me please what i connect the condensor on the outside of the distributor to?
Ignition Wiring
Posted 21 May 2025 - 02:56 PM
Posted 21 May 2025 - 08:06 PM
Posted 21 May 2025 - 09:01 PM
No Its a condensor mounted on the outside of the distributor. I believe it is a ducellier. I need to know where the wire from the condensor goes . also where the wire from the other side of the distributor goes, both to the coil i think, but which terminals please?
Posted 21 May 2025 - 11:19 PM
The black block on the side of the distributor that the wire comes out of has a terminal on the underside that the condenser plugs into. Make sure it's a tight fit as I've seen them be loose and work for some time until it decides to not make proper contact.
The wire goes to the coil negative but there's probably a white wire with black stripe which comes out of the harness for it to plug into. That wire then goes the short distance to the coil.
Edited by 68+86auto, 21 May 2025 - 11:20 PM.
Posted 22 May 2025 - 07:23 AM
