Rubber Front Doughnut Identification
Best Answer Edington , 22 May 2025 - 01:36 PM
Thanks for the useful info. I did in the end compress the cone to get the top ball joint in. Strange I never had to do it on number of others over the years, must be getting weak in my old age!
Go to the full post
4 replies to this topic
#1 Edington
Edington
  • 133 posts
Posted 21 May 2025 - 06:20 PM
Firstly are there different rubber compounds for these suspension units and if so how are they marked? I replaced a rather tired and partially collapsed doughnut with a new one I had in my workshop but can't remember it's history. Having fitted it I'm struggling to refit the hub :(
#2 mab01uk
mab01uk
  • 12,478 posts
Posted 21 May 2025 - 06:29 PM
You might find these articles in links below from Minispares on suspension cones of interest.
Mini Dunlop Suspension, Cones:-
https://www.minispar...2015/10/02/925/
FAM3968EVO Suspension Cone:-
https://www.minispar...uspension-cone/
Edited by mab01uk, 21 May 2025 - 06:38 PM.
#3 nicklouse
  • 18,654 posts
Posted 21 May 2025 - 08:07 PM
The ones from MPart are made to the original ingredients in the original tooling.
#4 Spider
  • 15,022 posts
Posted 21 May 2025 - 10:59 PM
If it's on the Right Hand Side, the Cone is more or less at original height and a standard trumpet was fitted, this would be correct.
You need to compress the Cone about 1/2 that needed to fit it to relieve pressure on it so you can lift the top arm or use something to otherwise lift the arm. I used to be able to get them with a 12" Shifter (adjustable) Spanner, but not now !
#5 Edington
Edington
  • 133 posts
Posted 22 May 2025 - 01:36 PM   Best Answer
